17x9 +35 with 215 tire?
Would a 17x9 +35 wheel with a 215 tire fit in the front with just a roll and some camber? Or would I need to pull the fender also? I have about 1.5 finger wheel gap up front.
Right now, I have a 17x7.5 +38 with a 215 tire and -2deg (maxed out) camber. What do I need to get more camber?
Thanks.
Thanks.
Former Sponsor
First a 215/35R18 is 1" shorter than stock and lower in load capacity than the car needs. I would not recommend the tire on the S2K. Secondly they are going to need to be stretched to fit on the wheels and they with a 35mm offset you are going to have to do some fender work to make it fit.
I would not recommend it.
