17x9 17x10 6ULR
#21
Curious which rims would be ideal for Direzza Star Specs.
It's daily driven with occasional track days. It's boosted so I'm looking for more grip at the back but want to keep some stagger for manners.
235/40-17 or 245/40-17 up front? (Leaning to 245, closer to stock circumference.)
How would clearance on the control arm be with the 9x17 +63 up front running a stock alignment and ride height with those sizes?
265/40-17 at the rear (16mm taller than stock, is this a big deal?)
Would the 9" or 10" be better for the rears?
Love these wheels, just want to make sure before I hit that order button.
#22
OK guys so let me get this straight, if i run the 17 x 9 +63 all the way around and have my s dropped about an inch on swift springs i wont need to roll or pull the fenders at all for these to fit?!
#23
#27
Playing around with different setups this afternoon.
The higher offset versions are perfect for milder street camber. The lower offset versions work best with race camber (-3 ~ -4°).
I'll bring samples to Spring Mountain S2K Challenge for test fitting next weekend. If anybody wants to stop by the shop to check them out, come on down. Just give me a call or email before you do so we can make sure to be in.
#30
Great visuals, that always helps - especially if you are from SC like me.
Is there a chance you could post a pic of with the following installed on the S together?
17x9 +63F
17x10 +72R
Not concerned with tire size.
Thanks
17x9 +63F
17x10 +72R
Thanks
