17x8 rims all round?
wrong width and wrong offset.
you are going to rub in the rear with 38 et if you lower about one inch.
no sure about the front, i think it might rub like a mofo also.
it will fit only if you run camber and roll the fender. how much camber needed would depend on how low of a drop you're going to run. I suggest staggering tire sizes so you don't get too much oversteer. you can get away running 225width in the front but its safer to run 215. the rear you can run 255's but I would recommend 245's.
