17x8/9 +45 with 245, will it need fender mods
Old 01-15-2010 | 11:41 PM
JmanS2k's Avatar
Thumbs up 17x8/9 +45 with 245, will it need fender mods
Basically I'm just wondering if I'm going to have to have the rear bumper tabs relocated or the fenders rolled on a swift one inch drop with a 245 tire and 17x8/9 +45 wheels? I want absolutely zero scrubbing with the maybe the exception of large speed bumps and so forth. I'm just trying to figure out if I want to have my mechanics mess with my fenders because if that's the case then I might as well go with a 255. I understand some negative camber might be needed but, I just need the rear fender modifications clarified because I'm reading a lot of mixed thoughts.
Old 01-16-2010 | 08:08 AM
Jim@tirerack's Avatar
Former Sponsor
I would say that with the 245/40R17 and a little negative camber you amy be fine. I would try that first before rolling the fenders.
If I can help let me know.
Old 01-17-2010 | 10:58 AM
JmanS2k's Avatar
Do you think RE-11's in a 215/245 setup would look too stretched?
Old 01-22-2010 | 12:58 PM
Eryan36's Avatar
A 215 is at home on a 7" wheel, so I imagine putting it on a 8" would stretch it a little. Then again, it depends on which brand tire you get.
Old 01-23-2010 | 03:02 PM
the_morbidus's Avatar
I am curious about that, you see the previous owner of my S2k bought Kazera KZ-F 18x8 225/40 R18 for the tire for the front and 18x9 255/35 R18 for the rear , and well i simply dont like them, never heard of the company before so I'm not sure how reliable they are, I was thinking about buying OZ Ultraleggera same wheel size and getting same tire size but this time some potenza RE-11 tires.
problem I was facing would be quite expensive tires, now i saw a video of J's Racing s2000 from thei 07 setup and they have enkei RPF1 wheels and it said 255/40 R17 all around, i assume they have 17x9 wheels all around.
Couldn't find any specs. on offsize but I was interested on getting them for Enkei wheel is quite cheap, does the 17x9 clear the front?
i think the previous owner installed the Tein type flex suspension just for these wheels, so I might already have the proper camber setup but i'll do an alignment for it when i get them.
Old 01-23-2010 | 03:16 PM
JDMQuip's Avatar
17x9 +45 on the Enkeis all around will need a definite roll on all 4 corners. Depending on how low you are you might also need a mild flare in the front as well. Relocate the bumper tabs in the rear and trim the liners is also in order.
Old 01-23-2010 | 03:22 PM
1nate7's Avatar
It will be a minor stretch but is perfectly fine. Those are the tire sizes you need to run if you don't want to roll.
Old 01-23-2010 | 05:00 PM
well my worrying is not so much about if it will hit the fender on top since im running 18x8 on the front atm, the problem is when i do a full turn with the wheel, will a 17x9 rub on the inside plastics?
Old 01-27-2010 | 06:42 AM
rioyellows2k's Avatar
I'm thinking about getting the RPF1 in 17X8/9+45. But I want to run 225's and 255's. I'm OK with rolling fenders and relocating the Tabs is there anything else I need to do? I'm 1" lowered, with -1.5" MAX in the future.
Old 01-28-2010 | 09:26 AM
candyteggy's Avatar
i have 215 on 8" in the front, and 245 in a 9inch on the rear... its def stretched a little but not too bad..
