17x7.5 +48 and 17x8 +45
Old 01-29-2011 | 10:56 AM
BowlofRice's Avatar
Default 17x7.5 +48 and 17x8 +45
So my car is lowered around .75 inches. Or 25.75 inches from the floor to the top of the fender. I was thinking of picking up some wheels 17x7.5 +48 front and 17x8 +45 in the rear. The tire sizing looks to be 225/45 front and 245/40 rear. Will I be needing fender mods or should I just pass it up for a better set with optimal offsets?
Old 01-29-2011 | 12:51 PM
Jim@tirerack's Avatar
Former Sponsor
Maybe just some negative camber with that set up. If I can help with the tires let me know.
Old 01-29-2011 | 01:35 PM
BowlofRice's Avatar
More camber then stock? I'm at 1 degree in the front and 2 in the rear. Effectively the uk alignment.
Old 01-31-2011 | 01:29 PM
rohde88's Avatar
maybe, its hard to say without test fitting your particular brand of tires. As you know, some brands run wide, some run square, some are round, etc. Once you lower it and push a little lower offset, you're going to need to run some Falkens with a round shoulder if you want "safe"
Old 01-31-2011 | 02:22 PM
clarkster009's Avatar
I would not run that setup...I think the 8" rear is too narrow...plus there is only the 1/2 in stagger. What wheels are they?
redbaron
06-28-2011 05:26 AM
Unstopoulos
03-29-2011 03:31 PM
Integra21
09-03-2008 02:41 PM
ONO
02-16-2008 03:11 PM
jdmgpw04
02-09-2008 07:45 PM
