17x7.5 +38 with 215 tire - will I rub?
My wheels are 17x7.5 +48 offset, but I need to run a 10mm spacer, so effectively it becomes +38 offset. Running a 215 tire, will 17x7.5 +38 setup rub? Would I need to roll the fender or would just added camber be enough for no rubbing? If more camber, any idea how much is needed?
BTW, I'm looking at the Ichiba V1 10mm spacers that include 10mm extended studs. Anyone have experience with these? I've read a couple of online reviews saying the studs are soft and broke, but those were the V2 spacers with the pressed-into-spacer studs.
Thanks.
Thanks.
Thanks.
Thanks.
These are the front. The spacer is needed to fit a BBK.
I only found one thread of a similar fitment where someone stated that 17x8 +45 with 215 tire *should* fit without the need for rolling, but that was never verified. 17x8 +45 is less than 1mm further inward than 17x7.5 +38.
sofresh&soclean
04-03-2010 04:11 PM
