17x7.5 +36 fronts 18x9.5 +39 rears.
Old 02-18-2011 | 10:08 PM
cts206's Avatar
Default 17x7.5 +36 fronts 18x9.5 +39 rears.
I found a great deal on some c2 2 piece wheels that came off of a nsx. the size is 17x7.5 +36 in the front and 18x9.5 +39 in the rears. I been doing research on this site and know that the rear fender has to be rolled. and maybe the front as well. my question is what size tires should I buy in order to keep the fender rolling/flaring to a minimum?
Old 02-19-2011 | 10:47 AM
Mar48's Avatar
depends on how low you are... if you're slammed then you'll need a lot of camber to keep from rubbing + fenders fully rolled.
Tire sizes the skinnier you go the more room you'll have, and obviously that has a negative trade off with handling.
If you roll your rears you might as well roll your fronts.
Old 02-19-2011 | 05:02 PM
cts206's Avatar
I don't want to slam it. just enough to have a clean flush look, maybe 1.5-2". I don't really mind rolling the fender but do you think I'm going to need to flare it as well? I still want it to look as stock as possible
Old 02-19-2011 | 05:42 PM
Mar48's Avatar
rears should be ok with a roll although you might need a lot of camber and very conservative tires (245s?)
Old 02-19-2011 | 06:49 PM
cts206's Avatar
yea I'm thinking 245/35/18 for the rears. what do you guys think about the fronts? 225/30?
Old 02-19-2011 | 07:54 PM
1nate7's Avatar
215/40 front is the best match to a 245/35 rear.
Old 02-20-2011 | 10:42 AM
cts206's Avatar
does anybody have a picture of a similar setup? or with 17s in the front and 18s in the rear? I want to see a side shot to make sure it doesn't look funny
Old 02-24-2011 | 04:40 PM
cts206's Avatar
nobody is running 17s in the front and 18s in the rear??
Old 02-24-2011 | 07:02 PM
Mar48's Avatar
you can search, I've seen only a couple running double stagger
Old 03-01-2011 | 02:49 AM
cts206's Avatar
finally some pics. so should I pull the trigger on 215/40r17 for the fronts and 245/35r18 for the rears? is this the best tire sizes for theses wheels? I plan on lowering the cad about 1.5-2" and rolling the fenders, no flaring.
