17x7 +48 offset?
17x7 +48 offset?
I can get a good deal on these rims, but all 4 are 17x7 +48... stagger with tires?
... will this work?
They also come in these sizes as well:
17"x7 +53
18"x7.5 +55
Can any of these work on our cars? If so what tire sizes?
Sorry couldn't find the offset chart here.. Thanks in advanced!!
... will this work?
17"x7 +53
18"x7.5 +55
stagger is when you have different width on the front and rear so 17x7 all around is not a staggered setup....also pick the highest offset you can for the wheels front for ap2 wheels is 55+ and rear is 65+ so those 53+ that you can get for the 17's is pretty dam good fitment....
ok updated the widths.. if I do get the same size wheels I understand I can get wider tires in the rear.. I just need to know what tires and which rim sizes dshould I get... Thanks again for all your help!!
thanks turbopwr ... now the deal is I can only get 17x7 +43 offset.. will the 215s for the front and 245s in the rear be ok for those rims?
I can also get aset of rims 18x7 with 45 offset all around.. can i use these? what tire sizes would i need to run?
