17x10 fitment
Old 08-10-2012 | 06:59 PM
Phill24's Avatar
Default 17x10 fitment
Sup all...im trying to get some info b4 i order a set of rims..i want to run either a 275 or a 285 40 17 tire and rim for the rear....im looking at 17x9 and 17x10 rims according to the wheel fitment guide i should order the 17x10 +65?? If i order with that offset would i still need to do fender work? Does any1 on here have any pics of they're car with that exact fitment?...for the front i was thinking 17x8+55 using 235 40 17 tires
Old 08-10-2012 | 08:19 PM
Dreaming_S2k's Avatar
First of all, 285/40/17 and 275/40/17 are going to be VERY tall (27.1" & 25.7" respectively). An alternative that would actually make sense in regards to overall diameter is either 265/40/17 or 295/35/17. If you do 235/40/17 fronts, you're going to get a pretty staggered height as well between F & R.
17x10 +65 is a good size, but if you don't want any fender work at all I'd use the 265/40/17.
Old 08-10-2012 | 08:30 PM
jlozano180's Avatar
https://www.s2ki.com/s2000/topic/964...#entry21842686
You can do what this guy did to get 275s on the car. That is what i am doing when i do 275.
Old 08-10-2012 | 11:41 PM
Phill24's Avatar
Not bad but thats with him at stock hight my car is a lil lower... I can fit 2 finger between my tire and the rear fender
Old 08-11-2012 | 07:15 AM
Performance Rush's Avatar
Former Sponsor
The people above gave good advice. Is there any reason you want such wide tires? Do you have additional power upgrades or anything?
Most people that track their car stick with the 17x9 and 255/40/17 because the tires are cheap (well, in comparison to wider tires, or 18"), and almost every tire is available in that size. Unfortunately they do not make a 275/35/17 ot 285/35/17. As mentioned, the 275/40/17 is a little bit tall, but people have managed to make it work.
Are you getting custom offset wheels (like CCW) made? I don't know of any other wheel maker that makes a high offset 17x10, other than the 6ULR wheel in 17x10 +72 that was discontinued. The next closest option is the SSR Type F or Type C in 17x9.5 +65, and 17x8.5 +58 up front. A 275/40/17 and 235/45/17 would be roughly the same height, although taller than stock.
Another option to consider is the 285/30/18 tire size...it is about the same height as stock. However, the 18" tires are about double the price, and you would probably have to have a custom offset wheel made because I don't know of any off the shelf wheels in 18x10 with high offset (except in the Porsche bolt pattern).
Old 08-11-2012 | 05:52 PM
Phill24's Avatar
The reason i want to run a wider tire is because im make 706 hp the current size i have 235 45 17 dont hold the power in any gear even in low boost..i understand some ppl run 255 and 265 and like it how ever i choose 275 or 285 because i like the look/performance of a wide tire...yes i am having custom rims made..they told me i could do either the 17x10 or 17x9...i was going to tell them do the 17x9 because somone i know is currently running that on they're s2k with 275 tires
And its sits perfectso i figureif i can do the same with the power im making that would be great..would be even better if i can run a 17x10 rim
Jim@tirerack
04-04-2013 06:49 PM
s2kZac
02-23-2010 05:15 AM
AndyThomason
01-20-2009 01:31 AM
P-CarDriver
01-16-2008 05:10 PM
M32
10-13-2005 12:57 PM
