17 in. Volks... Opinions on tire size
Old 08-22-2006, 11:08 AM
MugenRioS2k's Avatar
Fronts should be fine with a .7deg neg camber.
no fender rolling necessary for the front
Would most likely need to run 2deg of neg camber in the rear and move the bumper bracket toward the rear and a possible fender roll.
Old 08-22-2006, 11:35 AM
Dave-ROR's Avatar
well the rear wheels in my case are +63.. so that would be fine I'd assume.. unless you were talking to the OP.
Old 08-22-2006, 11:40 AM
ok +63 are good to go for the rears
only the front may require more cambers if you are lowered. if at stock height you may get away with no adjustment necessary on the front.
Old 08-22-2006, 11:46 AM
Dave-ROR's Avatar
Thanks for the info.
The car is currently at stock height, and likely will be for a bit. I tend not to modify the suspension until I feel it needs it, and I know I'm not good enough to drive it at it's true limits right now.
Old 08-22-2006, 01:26 PM
derek14's Avatar
LOL damn thread-jackers.....
Its cool, I just hooked up a set of BFG G-force kdw2's (255's and 215's) for 400 bucks a full set through my dealer friend
Thanks for the info guys...
Old 08-22-2006, 01:53 PM
Dave-ROR's Avatar
LOL I had a similar question and didn't really see the point of creating another thread on the same topic.
Sorry if it offended you or something.
Old 08-24-2006, 05:24 PM
lagunaS2000's Avatar
I am buying a set of TE37 rims in these sizes and recommended tires:
17x7.5 +50 -- 225x45x17
17x9 +65 -- 255x40x17
Can I run 06 stock tire on them? If not, can I also run 215x45x17 in the front??
Thanks
Old 08-24-2006, 06:42 PM
Dave-ROR's Avatar
Yes you can run the stock tires on those.
The_Chosen_One
11-30-2010 03:53 PM
monsoon monster
07-07-2008 01:45 AM
purehonda
03-19-2007 07:04 PM
Fuelrush
02-13-2007 11:50 PM
rai
11-12-2005 04:22 PM
Quick Reply: 17 in. Volks... Opinions on tire size
