17" Volks ce28 tire size
Old 11-02-2005, 09:15 AM
rai
rai's Avatar
Default 17" Volks ce28 tire size
17x7.5(f) 17x9( r)
What size tire would be recommended?
Looking for neutral handling (if anything less oversteer).
I've noticed the rear tires wear 2x (or 3x) as quick as the fronts; does this lead to more oversteer as the fronts have more tread most of the time? Will slightly more stagger tire size than stock work any better?
Old 11-03-2005, 12:59 PM
Former Sponsor
Jim@tirerack's Avatar
What is the offset of the wheels?
Old 11-03-2005, 01:06 PM
rai
rai's Avatar
17x7.5 +50
17x9.0 +63
Old 11-03-2005, 06:04 PM
illicit's Avatar
id like to know too. also same specs but front wheels have a 10mm spacer because of new brake calipers. what size do you suggest to prevent rubbing? sorry to hijack
Old 11-03-2005, 11:01 PM
GrimReaper's Avatar
I've got the same wheels/size/offset. I'm running 225/45/17f and 255/40/17 rear. No rubbing. I'm on stock suspension.
Old 11-04-2005, 05:36 AM
ZSAK's Avatar
do you have any pics grimreaper
Old 11-04-2005, 06:48 AM
ep3minivan's Avatar
I have had a couple of sets. Both have been +50 & +63. On my first set I ran ES-100 225/45/17 and the rears were a little small. So, on the second set I went AD-07s with the same up front and 255/40/17 in the rear. I am dropped about 2.5 inches and I don't rub much. When I do, it is just on sharp inclines (going into my driveway) and that is up front.
Old 11-09-2005, 03:06 PM
Amuse Boy's Avatar
Front: 225/45/17
Rear 255/40/17
Old 11-09-2005, 10:52 PM
s2ka's Avatar
The stock RE050 tires fit perfectly and handle great, tough to beat.
Old 11-11-2005, 09:53 PM
Adubz's Avatar
ce28n's everywhere!!! nice wheels guys! my 17in ce's in ti gunmetal's coming in next week! i went with OEM for 17s sizes. BFG KDW-2. never tried these before. i like the 300 treadwear.
Quick Reply: 17" Volks ce28 tire size
