17" Tire Sizing
17" Tire Sizing
Can anyone help me with wheel diameter and tire sizing for 17" rims? I'm getting some mixed msgs...on TireRack, they suggest 205/50/17 and 225/45/17, while some people I know are running 225/50/17 and 245/45/17...I'm looking for the closest fit to the stock diameter, but I know it won't be exact, so I'd rather it smaller than bigger of the stock diameter.
Thanks in advance for any info!
Rich for stock diameters and stock width ratio between frt/rear you should use 205/50-17's and 245/40-17's. Both rolling radii are within 1% of stock, the rears being slightly smaller than stock (incase you were wanting to split some gearing hairs).
Originally posted by ukliam
What about for 18"s?
225/40-18 frt
285/30-18 rear
but you're not going to find any reasonably priced wheels that can handle those (the correct) sizes. Go with 17's unless you can afford to go nutty.
so you should not go with:
225/40-18 Fronts
255/35-18 Rears
then?
Is that right, what would that setup effect, would the handling and traction be bad?
There are several people on here running it, perhaps some comments from you about the differences over stock.
225/40-18 Fronts
255/35-18 Rears
then?
Originally posted by RT
Liam, this old thread may be an interesting read for you on the subject
https://www.s2ki.com/forums/showthread.php?...?threadid=34606
It boils down to keeping the rears about 25% wider than the fronts.
