17 Inch TE37 SAGA Release! S2000 Sizings Available *New 2017 Kamispeed*
#81
I'm not seeing any hard oblique shots of Face 1. I'm not sure about what appears to be a convex look, based on Rays' face diagram, where the spokes stick out proud of the lip for over half their length to the center. Looking at 17x7.5 +48 and 17x9 +61 which are both Face 1. Hesitant to look at different sizes/faces because I'm lowered and my LF already rubs slightly (CE28N 7.5 + 50).
Kami Speed (04-02-2018)
#86
Sorry all! I was away for the Holiday Weekend and just came back to a bunch of PMs so bear with me!
What size tire are you running? Also depending on how low you are, camber spec ect. You may experience rubbing under certain circumstances. But that all depends. Most people with some camber and a slight drop experience no rubbing at all. Here is more of an angle. I will see if I can get better ones for you. We have a set of either color in stock if you are interested in purchasing!
You have PM!
Let me know
You have PM!
You have PM!
Let me know
You have PM!
#87
TE37 SAGA update! Got a staggered set of them in for a customer and tested some templates.
17x7.5 +48 Does not clear Spoon or Stoptech ST40 will need around 3-5mm spacer.
17x9.5 +58 Clears both the Spoon and Stoptech ST40.
Here is a pic comparison of 17x9.5 +58 Face 2 ( Left ) and 17x7.5 +48 Face 1 ( Right ). This should give you all a more real view of the face. Let me know if you have any questions!
1nate7 (04-22-2018)
