16" wheel fitment
16" wheel fitment
Thinking about attempting a varrstoen 16x8 +25 in bronze on my 03 silverstone. I would have the camber maxed out in stock form which I think would be about -2f -3r. What else do you think I'd have to do?
To start this should be in the Wheels and Tires subforum.
Second you will need at the very least a roll and slight pull, I have 17x9 +45 fronts with a roll, 245-40-17 tires and -1.8 degrees of camber. This setup sits nicely and doesn't rub at all. The wheels you want will stick out about 7mm more requiring more camber or stretching tires.
Personally I wouldn't bother with this setup, 16" tires have less availability in both tread pattern and sizing than 17's. You can also get a wider wheel with a higher offset that sticks out just as far while allowing you to use a wider tire improving grip over stock AP1 sizes.
all that work to only fit a 225 tire? seems kinda redundant. u wil for sure have to roll front and rear not sure if u will have to pull though. its going to b hard to fit that in the front depending how low u r. those offsets r too low.
