15mm Rear Spacer
15mm Rear Spacer
I want to run a 15mm spacer on the rear, what's the best way to do it? From what I've seen none of the H&R 15mm spacers have the integrated studs and I'm not looking to outright replace the studs because thats just way too much work.
Thanks,
Thanks,
Site Moderator
http://www.ebay.com/itm/ICHIBA-V2-15...a58f77&vxp=mtr
Just make sure your wheels have the indents since on the 15mm spacers the existing studs stick out a bit so the wheel needs indents otherwise it wont sit flush.
