1 Rear Wheel has more poke
Originally Posted by Conedodger' timestamp='1302630224' post='20457896
Get it aligned before you worry. If your toe is screwed up, it could explain it.
I had my wheels measured to make sure there wasn't something screwy, they were spot on as well. I also installed a Spoon rigid subframe kit and that didn't fix it either. I ended up running a 5mm spacer on the rear on just one side and it fixed everything perfect. Kinda ghetto, but I had the alignment checked and it was dialed in perfect.
The other guy on the boards with a GPW MY07 (same year as mine) that's SC'd with a Novi 1500, I think his screen name is "ilovemyhonda1984," had the same exact issue I did.
I still have no idea why it's like that.
