WTB: Oil pressure gauge
WTB: OIL PRESSURE GAUGE & NECESSARY ADAPTER
Looking for both items together or separately. Basically, I need everything to hook up the oil pressure gauge. I do not need a pretty gauge, just one that work. I no longer have the Defi Controller unit, so that rules out any Defi gauges.
Thanks for looking,
Skip
Thanks for looking,
Skip
Received this PM from a very trusted individual, Stratocaster, and ended up ordering the following parts:
OK, here is what you would need.
This screws into the side of the block.
http://store.summitracing.com/partdetail.a...15&autoview=sku
Next you need this. It comes with a few parts. The 1/8 NTP sender screws into the adapter above. You mount the gauge, supply power and ground to the gauge, and connect the gauge to the sender.
So for less then 100, you have an oil pressure gauge, and no block adapter that will be a PIA for oil changes, and the added risk of FIRE is it loosened.
