window leaking
window leaking
I was washing the car today and noticed that water is getting through the driver windown. It seems there's a small leak where the two rubber seals on top of the window join. I guess it's back to the dealer for another ass ripping.
sometimes it is just water pressure that is causing the leak.
Also, window without a frame is more vulnerable to leak compare to those with a frame.
i think as long as it is not leaking when raining then it is ok.
Originally Posted by Indecision,Apr 11 2008, 08:18 AM
What you need is some Shin-Etsu silicone It'll soften up the rubber seals.
When it rains really hard, I get some water leak in the driver side weather strip. I never had this happen before then one day I came back to the car to find the driver seat wet. I took the weather strip apart from the soft top and could not figure out where the water was coming from, but there was lots of water in the weatherstrip.
A few months went by and this problem did not return. Weird.
Same with the ept sealer
