Removing AP2 front bumper
I removed all 18 screws/bolts but then i cant seem to pull it off the hooks around the headlights. Do i just use pure force and pull it out or is there some trick to it?
this is so frustrating >=(.....
thanks for the help!
LEs
LEs
I found this was a pain in the ass too but it helps to make sure the middle section of the fascia is un-clipped first. Also, try pulling the bottom corner out a little as you pull straight back. Once you get the angle of the dangle just right, it should just pop out.
Or you can just get a case of beer and a pry bar.
Originally Posted by viNz86,Feb 7 2010, 04:07 AM
Your car is still a virgin, once you start removing panels and parts things will come off easier haha
haha, not a virgin anymore >=D!
its took a while but it finally came out, hmm now the problem is.... how hard is it to put it back on ><!
Theres a tool just for removing clips? if it makes my life a whole lot easier i would def like to invest in one.
Thanks for the help!!
Originally Posted by kenny_son,Feb 7 2010, 01:09 PM
i hate those clips......zap straps FTW
Well it seems the bumper i got needs a bit of tampering but it looks like it'll fit decently at least. Im going to need to drill some holes on the bottom for the bolts though =\ (they have where to drill marked out though, shouldn't be too bad).
