Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
different brand tires on front and rear advice
Old 04-13-2010, 08:56 AM
jon604's Avatar
Default different brand tires on front and rear advice
How many of you guys use different brands of tires on the rear and fronts? I just wonder how it would affect handling. Anyone notice any difference?
I have a nail on a rear tire and noticed the inner edge is almost bald while the other rear is fairly new. Sadly I will replace both rears as that tire model is discontinued (Kuhmo Supra 712)
Was looking at the hankook ventus v12 evo (since it's so cheap @ Discount tire) or Potenza RE760 sport (Costco) for the rear... I currently have a 255/40/17 (rear) and 225/45/17 (front) set up.
Old 04-13-2010, 09:29 AM
S2S
S2S's Avatar
basically if the better tire is on the front then the more you will get bent. if the better tire is on the rear the less you will get bent. under harder cornering of course.
Old 04-13-2010, 10:10 AM
jon604's Avatar
more bent = oversteer?
Old 04-13-2010, 10:38 AM
manuelisfun's Avatar
I don't see it being a big problem especially if both tires are of similar performance. I think the problem comes when you have different tires on left/right.
At one point I ran RE-11s on the front and S02s on the back, and it would have a bit more tendency to oversteer, but that was kind of predictable.
Old 04-13-2010, 03:46 PM
Matt15's Avatar
if both tires are comparable you won't notice any difference daily driving.
Old 04-13-2010, 03:51 PM
604toaster's Avatar
S2S is right on this one.
I had grippy fronts and crappy rears before and it was really easy to kick the tail out.
Old 04-13-2010, 05:06 PM
SumAznGuy's Avatar
Do you plan on doing anything dumb in your car on the streets?
Most likely, you won't notice the difference on the streets.
For track/autoX, I noticed the difference as I had really old Kumho MX's in the front and newerish Kumho SPT's in the rear.
In this case, you will have newer tires in the rear so your car would understeer more, if you were pushing your car.
Old 04-13-2010, 06:06 PM
legin_k's Avatar
better tires on the rear.. forwards into the wall
better tires on the front.. backwards into the wall
keep in mind, though, that tires can have different warmup and wet grip characteristics, so the grip balance may not be predictable..
Old 04-13-2010, 10:07 PM
wowowox's Avatar
You will feel it when you corner, the car will be less predictable. Just what I think.
Old 04-13-2010, 10:40 PM
604toaster's Avatar
You won't feel it when you are downshifting unless you are downshifting so badly that the car jerks. When i went from mismatched set to complete set, the car was more event front to back. I drove on mismatched set for one summer and also autoxed on them.
It looks like you're gonna have more grip on the rear than the front with the new setup. When you go into a corner, you're gonna understeer easier. My advice is to get the rear tires that have similar grip levels.
Quick Reply: different brand tires on front and rear advice
