cel light
cel light
hey guys car is running a p4011 secondary air pump
replacement on the pump shows huge dollars, it sounds like its working properly when i start the car every day any advice anyone experience this?
book shows codeP0411 secondary air injection system incorrect flow. Note there is no code P4011 only P0411.Check hoses cracks leaking plugged up .Check for vacuum at at the hose that goes onto air control valve. Make sure car is warm when checking. Next if all looks ok you need to check the air control valve vacuum control solenoid. It could also be the wiring to it check no. 6 fuse under the dash make sure its not blown. That's roughly what book says....
