Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Are these coilovers good = / ?
Old 04-30-2008 | 02:09 PM
profpin's Avatar
[QUOTE=ALFYonso,Apr 29 2008, 04:58 PM] I take back what I said earlier... true, the springs are shorter, but they are the same spring rate.
Old 05-06-2008 | 07:40 PM
ALFYonso's Avatar
Originally Posted by profpin,Apr 30 2008, 02:09 PM
yes they do compress at the same rate but now the stroke of the stock suspension have lost its full functioning travel due to the drop.. the stock suspesion is only design for the specific ride height that it was engineered for..( sorry if i misspelled)
in my guesstimate, anything lower than .75in will affect the stock shocks..
the bad part about the s2000 suspension is that the body of the shocks is just way too long for this car.. they should of used a shorter body shocks from the getgo..
I still don't see it. I can see the system being underdamped if the springs are too stiff, maybe. I'm far from a suspension engineer, but it seems like the major characteristic of a shock is how much force is applied for a given velocity. Is the velocity of spring compression changing? I doubt it because the spring rate stays the same. True the shock might not be moving through the same range anymore, but I don't know if that affects damping rate.
Old 05-07-2008 | 12:19 PM
profpin's Avatar
you just answered your own question..
Old 05-07-2008 | 02:35 PM
ALFYonso's Avatar
How does it affect damping rate then? At this point I'm just curious. I mean, a fully loaded car wouldn't be considered to operate in the same range as the spring has been compressed a little further.
p-p-porkchop
01-11-2008 11:13 PM
Sticky2k
12-16-2007 02:50 PM
XLeezardx
10-18-2005 07:54 PM
thai12
12-22-2004 09:41 PM
ninja.s2k
11-10-2004 07:23 AM
Quick Reply: Are these coilovers good = / ?
