Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
Remedial Question that I should know
Old 05-21-2007 | 05:04 PM
Sgt Skidmark's Avatar
Default Remedial Question that I should know
So recently (within the last 5 months) my car will pull to the right sllightly if I apply the brakes softly without my hands on the wheel.
Anyone know the root cause of this ?
My front and rear pads were replaces a year ago as was the fluid. Since then there have been no track days, just a daily driver not driven hard at all. (I know - complete waste)
Old 05-21-2007 | 06:45 PM
moonliver's Avatar
real mechanics feel free to chime in
in order of liklihood.
1. Alignment
2. Not Free moving pads. (dirty stickiness)
3. Bad caliper
4. bad proportioning.
Old 05-21-2007 | 06:54 PM
jeggy's Avatar
quickest, easiest, cheapest, and mostlikely the cause....tire pressure.
Old 05-21-2007 | 07:28 PM
pushin9's Avatar
If you let go of the wheel and don't touch the brakes does the car go dead strait?
If so that would rule out both Tire pressure and Alignment
Also does the car still brake smoothly? Or does it have any jitter or shake?
Old 05-22-2007 | 04:36 AM
hondamanwill's Avatar
First I would check the left rear brake caliper. A rear caliper will make it pull. If it is a right rear locking up it will pull left same for the other side. Front calipers locking up would make it pull under brake to whichever side the caliper is locking up at. Make shure the pads are not tight in the brackets. I showed the guys at the KBAB that to take the clips off and clean the caliper bracket, rust will cause the pad to get stuck causing uneven wear and pad drag.
Old 05-22-2007 | 06:03 AM
rustywave's Avatar
this is usually if the car pulls during acceleration or shifting right? but not usually braking?
Old 05-22-2007 | 06:31 AM
ruexp67's Avatar
Old 05-22-2007 | 09:09 AM
thanks all.
Old 05-22-2007 | 01:30 PM
rustywave's Avatar
did you figure it out?
Old 05-23-2007 | 10:04 AM
Not yet, I tried it last night and could not replicate it. Although this AM when pulling out of the garage it pulled when braking in reverse. Had to go to work so I had no time to look at it.
Chances are its just me and my mind. It doesn't pull very abruptly, I just don't remember it doing it.
Quick Reply: Remedial Question that I should know
