Clutch cable
Long story short... Can barely get my car into gear even when clutch is pushed all the way to the floor. Is there a way to adjust my clutch cable? I'm assuming under the dash by the clutch peddle. But I want to make sure.
Ps. Clutch is not slipping.. Put it in 6th and gunned it at 40mph and there was NO slipping. Any advice or info will help. Thank you in advance.
If it was low, check the area of the pushrod that comes through the firewall that the clutch pedal pushes on. The clutch master cylinder is known to leak if clutch fluid has not been changed regularly. Look for signs of wetness and/or droplets of fluid at the rubber dust boot.
yeah you'll need to replace it unless you want to keep refilling the MC. changing fluid won't help it. you can use regular brake fluid for your clutch.
