Battery Relocation
Yup...done it. Hard part was routing a power cable through the firewall. Other than that, you'll need to make sure you have a couple of REALLY good grounding points in the trunk area. The metal is covered with a strong anti-corrosion paint. You'll want to make sure that once you get a good ground, you'll want to throw some sort of rubber sealant over it.
I didn't have that problem though, I used grounding spots in the roof well area. I don't have the soft top on the car anymore, it make battery relocation cleaner and easier.
If you will be driving your car in winter I would suggest running a separate wire for ground, but that would be a suplement to the common, so it wouldnt have to be as big, a 8ga would be adequate.
