Genuine Mats from WB Performance!
#1171
Correct. You get a new "Fitting Kit" with the mats and need to replace the existing one with the new one. (Unless you already had 4 piece mats.
I replaced my 2 piece mats and was quick and easy to swap the brackets over. Although need to make a small cut into the carpet in places to fit the new brackets.
Si@Hendy Performance (04-24-2017)
#1172
My 02 already has the factory anchors in the driver's side. They appear to be bolted to the frame, so no way to remove them. I just assumed the hendy mats would have a hole the same size as the stock mats so they would easily fit in there, but that's not the case.
#1173
The factory anchors were actually installed with the mats - you should be able to remove this and fit the newer version.
#1174
Si@Hendy Performance (04-25-2017)
Si@Hendy Performance (04-26-2017)
Si@Hendy Performance (05-22-2017)
