Xenon not working?
Xenon not working?
Morning everyone. Hope you all had a good christmas.
The S hasn't been used really since the snow started. Its been parked on my drive and warmed up every couple of days.
I came to it last night now the snow has almost all gone to put some fuel in her and give her a run out and noticed my passenger side xenon wasn't working.
I've already had a problem with this side having condensation in it, and i've had it out and attempted a fix a few months ago dried it all out etc but it soon came back.
Questions is: has anyone else had condensation in them? Can the bulbs be replaced or does it require a full unit?
And is there any difference between 05 on and earlier models?
Fortunately the car is gonna be off the road for about a month or so while i get some stuff done (test lightweight pulley kit, get ecu sorted, ceramic coat exhaust etc) so its not a major issue but its very annoying.
loftust says:
I've got a reoccurring condensation problem too
If I remove the rubber cover from behind the main beam lamp and leave it exposed for a few hours...the problem usually disappears for a few months
When you say Xenon...do you mean the HID lamp?
If so, have a search for 'replace HID bulb' and all will be revealed
I had this before and a ballast unit was blown, just check to see if theres power going to the ballast unit itself.
Dry the headlight on a radiator overnight and then apply silicon all the way round to the edge where the clear meets the black.
Originally Posted by Squeak,Dec 30 2010, 03:11 AM
loftust says:
Im going to take them both off this weekend and give them a good clean and refurbish.
Ill check all the wiring etc too. A hell of alot of grit got into my engine bay when driving back from the MASE day (12.5 hour journey )
She deserves a good enginebay cleanse
Originally Posted by Ste_Nova,Dec 30 2010, 03:52 AM
balast full of water
Thanks for the help guys, ill see what the full story is this weekend
