Wishbone re bush on axle stands ?
Is it possible to remove the front and or rear wishbones without a ramp ?
My 2004 is showing slight uneven tyre wear on the near side front, so I assume the geometry needs checking and adjusting.
I did try a big bar on the the front adjuster wishbone bolt but as expected it would not move,
Is it worth trying to get an air wrench on the bolt or is a big bar the best option ?
And if that won't shift it cut through it with an alligator saw.
So is that feasible on axle stands ?
Yup, doable but hard work and one of those jobs you'll only want to do once. Save it for when you don't want to drive it for a few weeks, then you can get the wishbones blasted and powder coated while you order the bits you had to cut and break to get them out. Get a big bar on the nuts, if that doesn't work see if you can drift them out with a hammer then get the sabre saw out with a proper blade for super tough steel (you'll snap one so buy three)
Thanks Ben I'm going to soak everything with plusgas for several days first and see if I can
get them to move.
The tax is out at the end of September so I'll take it off the road, then I can take my time, and do it properly.
get them to move.
Re bushed my rears without removing completely,dont think you can get the front <rear arms> in poly its non adjustable anyway.
on axle stands outside in December
Used a reciprocating saw and hole saw.
I did mine on axle stands, but I bought a set of wishbones beforehand and painted and prepped them off the car. Sold the set that I took off. Rears were easy. Fronts ... buy a reciprocating saw and lots of decent blades.
It's fairly easy on Axle stands , but take care you might find yourself pulling and pushing and puffing , so always take additional precautions at least stick your wheels under the car to where you are working , buggered wheel is better than a day out with an undertaker !
Also take note of the condition of the ground the axle stands are on , if this is not stable or substantial use some ply or such like to spread the load under the stands , not chip board ! I have to do mine on a Tarmac drive , I have no idea what's under the Tarmac , so I use 2ft squares of 1 inch ply under the stands or similar .
I wish I had drilled and fitted grease nipples to the bush housings .
I used to be a mechanic back in the 70's and 80's so should be ok re the risks
Having said that I know a mechanic who had a car fall on him.
So thanks for the reminders
