Window Reset
Window Reset
I've reset my drivers window so it goes up and down automatically, but when i turn off the ignition then on again the window doesn't go up or down automatically.
Would this be a switch problem ?, or is there another solonoid sort of thing somewhere else ?
Thanks guys for any input
Put the window up then press the up button for 2 seconds, put the window down and then press the down button for 2 seconds.
Works ok...then when i turn off the ignition and on again it doesn't work.
Putting the drivers window up or down in one go.
If you press the button normally the window goes up or down but if you press the button all the way down it puts the window down in one go or up in one go, the button has 2 setting...hard to explain really.
