Winding in those rear calipers
#31
1 Post
Well I now think that my front right caliper might be sticking. Everytime I set off there's a small "tink" sound, and there's pad shaped marks on the disk. And when I got home from a leisurely 3 mile drive home, the drivers side front disk was hot. I didn't think to test the passenger one.
It doesn't feel like it's sticking though.
#32
Originally Posted by Dembo,Jun 26 2007, 10:42 AM
I think I did have the caliper/pad not quite in right. Fine now.
I do believe my car is 100% working.
good to hear dave
#33
A pad shaped mark on the disc isn't uncommon. Sometimes you get corrosion appearing over night that doesn't appear where the pad is in contact with the disc, but does everywhere else that makes it look like a pad shaped mark.
#34
Originally Posted by Chris Type R,Jun 25 2007, 06:29 PM
Also, I think it's a little risky opening the bleed nipple as you stand a good chance of getting air in the system. I know this from trying
#35
Originally Posted by Si2k,Jun 25 2007, 11:02 PM
When you lift off the pedal the master cylinder simply removes pressure from the brake caliper and lines, there is no back flow.
The Honda ESM makes no mention of bleeding any fluid from the calipers when you retract the pistons, nor have i ever seen that in any other manual for a car equiped with abs.
#36
1 Post
Originally Posted by lower,Jun 27 2007, 08:18 AM
you need to compare one side against then other for temperature to get an indication of whether a caliper is sticking.
#37
Seems like you're just making more work for yourself.
Chilled: you haven't been stopping and sitting with your foot on the brake have you?
Question: How do you get to the pins? On my FTO, the caliper bolts were long bolts with a small threaded part at the top, and the caliper would slide along those. So when changing the pads it was good to give them a healthy dollop of grease to ensure they'd be able to move freely.
The S has small bolts, and presumably a pin or something in there that the caliper slides on. Should we be removing those and greasing them?
#39
I never bother putting more grease onto the sliders, just check that they move freely.
