Will a UK 2009 ECU run JDM 2001 engine
Hi boys and girls.
I am Maz, I am in the process is of getting my second S2000. To make it financially possible, I went for an UKDM 09 S2000 with a damaged bottom end. The top end is thankfully it in excellent working order. I am looking at a bottom end off a 2001 JDM engine to fit into the car, can I maintain the original UKDM ECU. It would be a bottom end swap.
Thanks in advance.
Thanks in advance.
also do the JDM engines (F20C) not run at a little higher compression to the UK engines (F20C2) and using the right fuel make 250ps instead of the UKDM 240 so would that have any knock on effect with the rest of the engine?
