Wheels - identifying size
Old 10-16-2012 | 11:29 AM
Stoatmaster's Avatar
Default Wheels - identifying size
Hi,
My wheels were removed recently to be powder coated. I've not long had them back, and noticed that both the 225 tyres are fitted to the near side, and the 205 to the offside!
It's possible they have just refitted the wheels incorrectly, but its possible they also have mixed up the tyres on the wheels too. Can anyone tell me how to identify which are the rear wheels and which are the fronts?
The wheels are 16" OEM JDM BBS wheels, there are only three markings I cn see on each wheel. BBS, Forged, and a symbol. Nothing about the widths.
Thanks
Old 10-16-2012 | 11:32 AM
WinFreak's Avatar
Just measure the width of the rim? widest go on the rear
Or measure the centre hole, the largest hole goes on the front
I'm pretty sure there must be more writing inside the wheel where it fits against the hub
Old 10-16-2012 | 01:10 PM
I thought there may be, I,ll pull the wheels off.
I didn't realise the centre holes were different sizes. I assume they will fit all the hubs?
Old 10-16-2012 | 01:18 PM
WinFreak's Avatar
The rears won't fit on the front, at least this is the case with the facelift 17s, but I assume it would be the same with yours.
Old 10-16-2012 | 01:28 PM
Scottland's Avatar
It should be imprinted on the inside of the wheels. It may be shown as 7J instead of 7 inches for example.
Old 10-16-2012 | 01:42 PM
keith2.2's Avatar
lol why would you not just measure the width? Or put two next to eachother?
Old 10-16-2012 | 03:35 PM
Because that will involve removing all the wheels, if I could check visually that would save me time.
Old 10-17-2012 | 12:04 AM
Simon W's Avatar
SO long as you are always turning right I am sure you will be fine.
Old 10-17-2012 | 12:21 AM
richmc's Avatar
Othwise leathal, don't take it out in the wet.
And it's not going to do your diff any good!
You could drive it (carefully) back to the place that did it and ask what f**king monkeys they employ get them put right and reballanced.
I've heard of some pleb storys in my time, but this one is first class! Name and shame.
Old 10-17-2012 | 12:38 AM
BenRNBP's Avatar
Sorry, but I did have a chuckle about this when I first read it.
I think most wheels will have the diameter, width and offset on the back of one of the spokes - you are going to have to take off the front left to swap with the rear right anyway so that's what I'd do to check. Hopefully, you're in luck and they put the tyres on the correct rims.
