Wheel removal
Wheel removal
Hi everyone,
I have been installing my CAI this morning, which requires part of the wheel lining to be cut. Everything was going fine until I tried to remove the wheel.
Now, I am sure I am just being stupid, so please don't flame me too much (my car didn't come with a user manual either, so I may be missing something fundamental)
So i've got the car jacked up, all nuts removed, but I can't get the flipping wheel off. Is there any hidden technique to this? Just off to buy some wd40 to try and loosen things up a bit.
Cheers
Cheers
I had a similar issue when removing my wheels recently. I found that grabbing the wheel on each side and pushing/pulling opposite sides loosened up the wheel which had almost "rusted" to the hub. Eitehr that, or a quite kick on the bottom of the wheel should do the trick (making sure the car is properly jacked up!!).
Hope that helps
Hope that helps
Just don't do what I have heard be suggested before, loosen the wheel nuts and go for a drive around a car park. Not worth the risk.................
Big rubber mallet or take it to the local tyre place.
Just use lots of this when you put them back on...........
Originally Posted by m1bjr,Nov 29 2008, 02:32 PM
Hey, if you have REALLY hard springs it will drive on 3.
Wont it?
Wont it?
http://www.videovat.com/videos/12778/wheel...off-an-rx7.aspx
