wheel help?
wheel help?
just wanted to know if this size would fit my ap1?
fronts are 17 x 8.5" Split rim
ET35 Offset
rears are 17 x9.5" Split rim with
ET35 Offset
had a vw in the past with bbs that was down and out et19
any advise would be great
jay
ET35 Offset
ET35 Offset
jay
my old 18" wheels where
front and rear 8.5j et 45 and i ran a 3 mm spacer all round to make them effectively et 42
my current wheels (yes the pink ones)
front
17 x8 et 34 and i have a 3mm spacer and they fit great
rear
17 x 9 et 36 no spacer and they poke out the arch by about 10mm with 2.2 degre's of camber so a 8j wheel would sit 12mm further in so would fit great.
so a 17 x8 et 36 will fit all round fine
17 x 8.5 et35 will poke out the arch by about 6 mm
to make fit add lots of camber, coilovers and stretched tyres, if your not going for stance no it wont look good
17 x 9.5 et 35 will poke out the arch by about 17mm so no matter what you do will look stupid
handling wont be affected at all if anything will be better from a slightly wider track car.
