Wheel fitment /tyres
Hi all
bought some wheels and they are 8" front et 48 and 9" rear et50 ( only cheap rota's)
can i run 225-45 and 255-40 without rubbing issues ?
And also can someone please confirm if these wheels will stick out stick out further than the wheels I have ?
Currant wheels
7" ET 40 215/45
8.5" ET 50 245/40
any help much appreciated
Currant wheels
7" ET 40 215/45
8.5" ET 50 245/40
If you reduce the spacer size from 15mm to 10mm, it shouldn't be a problem (but will they then clear your brakes?), but otherwise the rears are going to stick out 6mm further than the current wheels do - especially combining that with a wider tyre as well.
The fronts are going to stick out 5mm further (even with the more favourable offset).
Is that with or without the spacers?
If you retain your spacers, I still think your are going to get slight touching given the extra protrusion. Obviously without spacers, no problem what-soever in running those sizes.
Bodyboarder1981 (05-03-2017)
I have the same. 235 and 255 rubbed front and rear. I'm on coilovers and not mega low. Car is setup for track.
Rolling rears stopped them, fronts rub under heavy cornering, weight shifts and undulations.
Bodyboarder1981 (05-04-2017)
Originally Posted by Bodyboarder1981
Ah sorry mike ..... I'm thinking of removing the spacers completely. The above pic is with out the spacers .
So in lght of the new info ...... 225/255 should be ok ?
