What makes the fans/heater so efficient?
Hi all,
Nearly every person who has sat in my S2000 comments how quickly the heaters warm up and fans blow out warm air .
In other, much newer cars, it takes noticeably longer to reach a similarly cosy climate.
So, other than typical 'Honda engineering', what makes our heaters/fans so efficient?
Hi all,
UK Moderator
Most likely a well-specified heater (it's a convertible after all).
If you friends own diseasals then they will really notice the difference as those take forever to warm up.
Hot, high pressure engine which along with the gearbox is mounted very close to the cabin.
And probably setup to put a decent amount of the coolant through the heater matrix with it being a convertible.
Most normal cars can only make me sweat with the heater on full whack, I don't think it's because of the cabin size though because the S2000 can be painfully hot even in the dead of Winter with the roof down.
It seems to be a "big" flow heater matrix, excellent when the top down setting is on...err with the top down of course... as opposed to the aforesaid mentioned Diesel taking a really long time to heat up..
My van has really good heater too but the time to heat up the 1.9 turbo is triple that of the S2K...
If you want a REALLY hot car get a ride in a Triumph GT6 ! standard issue shorts for the winter
Possibly a stupid reply but doesn't the fact its a smaller cabin space contribute to the warmth? plus the gearbox and drive train, i can feel the heat from it on my leg. My old MR2 always got warm inside quickly too, put it down to being a small cabin space and the engine alongside your back.
? My BM is the same, instant heat, I agree re diesels and the point about tiny cabin is probably right
The air coming out of the blowers can be significantly hotter than any other car I've had which has to be that more of the coolant is diverted through the heater matrix.
My bro used to have a Rover 416i with a dicky head gasket that would need the heater turning on full whack on occasion to help keep it under control. Even in the middle of Summer that cabin with the heater on full and the Windows down didn't get close to as hot as the S2000 can in Winter with the roof dropped.
