What grease is used on the caliper pins?
Old 03-27-2015, 11:19 AM
Santenay's Avatar
Default What grease is used on the caliper pins?
As the title. I am in the process of rebuilding the calipers after completely striping them down and having them refurbished and painted. On the rebuild I will use silicone grease on the pin boots, but what grease do you use on the actual pins?
Old 03-27-2015, 12:57 PM
C3wrb's Avatar
Hi, I used cv grease as high melting point, not had any issues.
Old 03-28-2015, 02:37 AM
dan_bourne's Avatar
ceratec is what youre after
Old 03-28-2015, 07:37 AM
Santenay's Avatar
Thanks, I will use that
Old 03-28-2015, 11:04 AM
C3wrb's Avatar
Has anyone else used cv grease on brake slider pins out of interest ? Just changed discs and pads and would rather redo pins if highly recommended not use cv grease. Thanks
Old 03-28-2015, 11:34 AM
AlyWW's Avatar
I've always used copper grease without any issue. I thought that's what everybody used?
Old 03-28-2015, 11:36 AM
jimmyb1978's Avatar
Yup I use copper grease
Old 03-28-2015, 11:37 AM
CHIPPO's Avatar
Marine water proof grease , like Fuchs Renolit 2
Copper slip is not for this application , and it will not resist water , it's to lube threads etc during assembly
Old 03-28-2015, 11:44 AM
C3wrb's Avatar
Should I remove cv grease or should it be ok.
Old 03-28-2015, 12:27 PM
CHIPPO's Avatar
It will be ok , there no great load , it's intermittent a bit of transmitted heat but the Cv grease is fine for that, it will be fine.
In my humble opinion not the first choice , certainly better than copperslip, it lubricates and is slippery , if u have dodgy boots and let's face it they are not exactly super tough in time it will get washed out.
Quick Reply: What grease is used on the caliper pins?
