what is the easiest way to derestrict my s2000
#21
Well if yours has been converted to mph/delimited i guess it would go that far, but stock JDM models (before any changes to conform with UK regulations) dont. Also JDM models cannot switch between MPH and KMPH like on a European/UK model. Mine stops at 180kmph even though you can keep going if you wanted, delimited with a Spoon ECU which is only a "adjusted" stock ECU.
#22
My JDM cluster would read all the way to the top speed once the RSM was fitted. It was one of the earliest MY99s too.
Stock JDMs will stop at 112...not sure where the assumption of 72/76 came from as mine definitely stopped at 112, and (180/8 ) x5 is 112.5...
Sent from my GT-I9300 using Tapatalk
#24
