What decat to match a js manifold and amuse exhaust?
No, you aren't anywhere close.
The maps Honda throw out are ridiculously rich and I do mean into the tens AFR up past 8500. For NA, 13 is what you want. Stoichiometric is 14.7, so you can realise how rich 10 is!
And besides, your assuming you are going to gain magic flow properties with this J's manifold
Does changing the manifold and removing the cat really cause the car to run lean? I would have thought that unless you change the intake or dive into changing engine internals then I would understand.
I suppose with the exhaust flowing better, more gas can leave the engine but wouldn't the air/fuel mix stay the same going into the engine?
Member
I have a Js manifold for sale.
Ron, incorrect.
With an intake / J's header / decat you will be lean to the point you are in the 14s for sustained duration in the upper mid range. Seen it several times with my own eyes. With an exhaust system as well you will be too lean and will need the ECU map tweaking.
https://www.s2ki.com/s2000/topic/762...#entry18311637
I also wouldnt be aiming for an AFR of 13, 12.5 would be safer.
Ron, incorrect.
MB, any chance you can sort a finance deal on your manifold ;p
10.0 to 14.0 is a huge difference, although with the intake, I would understand having a higher afr due to the volume of air going in. Surly if he was just to fit the header and decat you won't be near those figures?
Ron, incorrect.
https://www.s2ki.com/...7#entry18311637
Ron, incorrect.
UK Moderator
My limited experience relates to Kim's car at the dyno day we had last year where his dyno runs were abandoned by the guys at TDi because of potential damage due to some sort of alchemy problems.
He had the following fitted:
Fujita F5 Intake
DMS exhaust, manifold and decat
Fujita F5 Intake
Fujita F5 Intake
Fujita F5 Intake
Member
Ron, incorrect.
Ron, incorrect.
Member
Fujita F5 Intake
Fujita F5 Intake
