What Decat
What Decat
Hi thinking about fitting a decat i have got the 28mm exhaust mod with a K&N induction kit would like the exhaust to be slightly louder, i know it want pass a MOT when fitted and to fit blox cel fix, is there any other pitfalls i should know about and which is best decat please
Get a 60mm if you can, this is the s2000 stock exhaust diameter though most likely your only able to get a 63mm which is more than suffice and dont go bigger.
It will most likely fail an MOT, it wont make the exhaust much louder (only a little) and will introduce a rasp more than anything.
Any anti fowler is suffice etc all it does it move it further out from the exhaust stream so the increased flow wont knock it out of the expected threshold by the ECU.
Hi Tommy, a decat will make it considerably louder in my experience. You heard my car on saturday: FIPK, 32mm mod & decat.
Mine is a dms which I dont recommend because it split and needed welding. If you get a berk hi flow cat you might pass MOT, Lee has one so hes best to ask about that. HTH
