What Coilovers
Old 04-22-2007, 01:25 PM
G375 DAN's Avatar
Default What Coilovers
I've had my S2000 for 3 weeks now
I've put some 18" wheels on it and it looks gorgeous but sits to high
so i;m thinking of getting some coilovers to lower it but dont want to ruin the handling or performance
Can anyone suggest any coilovers (Soft springs of poss)
Thanks In Advance
Dan
Old 04-22-2007, 01:35 PM
Dembo's Avatar
Too late.
Bilsteins (much better than Nitrons).
Old 04-22-2007, 01:41 PM
mikey k's Avatar
What sort of
Old 04-22-2007, 01:42 PM
MB
Member
MB's Avatar
Ditch the 18's and get a wheel size which works with the car.
Old 04-22-2007, 10:30 PM
Paper Lawyer's Avatar
Originally Posted by Dembo,Apr 22 2007, 10:35 PM
Too late.
Bilsteins (much cheaper than Nitrons).
Lowering means other mods to ensure your geo is good. See my sig.
Old 04-22-2007, 10:47 PM
eSeM's Avatar
Originally Posted by Dembo,Apr 22 2007, 09:35 PM
Too late.
Beat me to it.
You get what you pay for.
Old 04-22-2007, 10:52 PM
grantedS2k's Avatar
Hello G375 DAN
I remember this problem well!
Most of the reading here will tell you that if you have 18s and you lower the car, you will probably get some rubbing issues (tire to plastic wheelarch liner or, even worse, tire to wheelarch), depending on whether you've changed the rolling diameter, got the correct offsets etc.
If you have a larger rolling diameter (overall wheel size), it also puts your speedo out of sync (larger circumference, more distance travelled, lower indicated speed).
If you have the wrong offsets the wheel may stick out of the arch and look silly, or they sit too far inboard and rub on your suspension.
And as PL mentioned above you will need a geometry adjustment!
To be able to answer your question more effectively, what 18" wheels do you have?
Old 04-22-2007, 10:58 PM
eSeM's Avatar
Originally Posted by Paper Lawyer,Apr 23 2007, 06:30 AM
See my sig.
Not easy to miss it.
Old 04-22-2007, 11:04 PM
Originally Posted by StevenM,Apr 23 2007, 07:47 AM
Beat me to it.
Just realised that Brian's comments on the Bilsteins aren't in my Nitron thread, but instead his comments are in my initial suspension thread.
Bilsteins are good not not great
I think my sig should be the alternative technical FAQ Steven
Old 04-23-2007, 12:18 AM
G375 DAN's Avatar
My 18" have low profile tyres so the rolling diameter hasn't changed
Would this still affect handling or performance? (Apart from weighing a bit more)
Quick Reply: What Coilovers
