Westy's Progress Thread
#271
It all helps... this was my thinking kind of anyway.... lol.
K&N typoon - location of filter for cold air, sound trusted brand.
Removeed front air dam - more air for k&n
Miltek exhaust - looks OE and no drown and decent company and 2.75" isnt small!!
HKS manifold - zircotec coating -- decent manifold designed for supercharged and improved torque and heat management solution with added stregthening to manifold.
Decat with cel fix - removes main restriction and no cel light.
No air con - less strain on crank/pulleys/alternator etc plus new belt
rear diff mounts - tranfer power better as less movement and more direct handling.
larger rad - heat managemt
thermostat -heat management
Fan switch - heat management
Stage 2 clutch - not over the top but good for daily and more power.
#272
When i fitted a smaller more restrictive oil cooler i noticed alot of pressure drop during vtec on track. At some points i was down to 60PSI which to be honest i wasnt happy with especially as before fitting the cooler i had 80psi. The vtec never cut out with the pressure at 60 psi but that doesn't mean i would want the lower pressure in an ideal world. Now i have the larger cooler i get 75psi which is much better, especially for my peace of mind!.
How are you finding the car with the lower engagement? i had an integra type r with the spoon ecu with the lower engagement. In the end i put the standard ecu back on because i missed the kick of the Vtec.
Oh and i wish i could get flashpro for my car but its not available and its a fair old lump of cash for an AEM EMS
#273
I remember reading your thread on the oil pressure drop, iirc the general idea was to fit a larger oil cooler as the smaller one was causing less flow/more restriction and the f20c has no problem flowing through a larger cooler After reading this I held off buying a thermkstatic end plate for the 13row mocal i have in garage. I was thinking maybe 19row. (When SC) thibk the SC comes with 13row for its oil too.
I like the improved torque, car gets down road swiftly. Its a bit more punchy or beefy to drive, if that makes sense. Its not crazy or alot faster just more nippy and progress is better. On motorway its better as power is there when you are asking for it as apposed to waiting for lift off at 6k.
#275
#276
It means if you spray water onto the radiator or intercooler the water helps dissipate the heat, this is a positive thing. Boosted cars suffer with more heat so I just wondered if anyone has used the oe design of the washer jets to help manag heat.
maybe along lines of. Switch added in and pipes not used with screenwashers and a small pump iswd to spray. Just an idea
I dont think rain makes tyres more sticky?
#278
wasn't taking the piss was a genuine question (just re read my comment and may have come across either way) surely the washer bottle would soak up heat from the bay though making the water warm? i know for drag racing they use c02 to cool them down
#279
If sprayed onto the intercooler it would help cool the fins and consequently the air inside the intercooler.
#280
