Westy's Progress Thread
Old 11-17-2014 | 09:43 AM
  #241
noodels's Avatar
The bolts have a collar on that butts up solid against header for a desired tension,
Berk not allowing for the slimmer test pipe/HFC flange here,and should maybe address when fitting.
I ground the collars off the spring bolts, thus increasing the available tension on the springs.
The thread on the spring bolts have a limit at this point so needs spacing so not to bottom out on threaded bolt.
I used a 10mm s/steel nut on each instead of washers,just because i had them and looked better than 5/6 washers.
Hope this helps,
sorry no pictures
Old 11-17-2014 | 11:10 AM
  #242
weatyGT's Avatar
Aha I think im with you, the bolts have a shoulder on them that doesnt work well the the berk decat bolt holes.
To get more tension you added some bolts over the top then you can tip up tighter
that was what I thought may work with washers but lile you said lots of washers may look silly so you used bolts you had to hand at the time.
Thanks for the detail. Very helpful. (Thumbs up... I dont know how to do the thumbs up picture)
Old 11-17-2014 | 12:37 PM
  #243
CynicG's Avatar
Originally Posted by weatyGT
Its a bit of a shame spoon dont have a small locating hole on tje brace for the metal sheild to sit in, maybe with a rubber gromit. :-( what are the options to keep it? Drill it yourself. Rest the shield on the brace and hopenit doesnt flap around? We left it off for now.
I agree. Just wondered if you bothered with it. Btw, was it you in Cosham about 6pm today? I was nearly blinded by shiny tips!
Old 11-17-2014 | 12:58 PM
  #244
weatyGT's Avatar
I wasnt in cosham today. My tips arent shiney at the moment more golden toasted colour Lol.
Old 11-17-2014 | 01:35 PM
  #245
weatyGT's Avatar
Standard parts are for sale in the for sale section if anyone is interested.
Old 11-18-2014 | 06:41 AM
  #246
weatyGT's Avatar
hard top on and quick clean.
Old 11-18-2014 | 09:00 AM
  #247
Krisbuc's Avatar
Does your manifold allow standard exhaust shield to be used ?
Old 11-18-2014 | 09:51 AM
  #248
weatyGT's Avatar
Hay Krisbuc.
Yes it does im considering having it zircotec coated and popped back on. So it keeps in with the OE look.
The HKS twisted manifold keeps the stock heat sheild, it is needed as the HKS manifold is used with the supercharger kit, which has the supercharger on the side of the engine by the manifold.
New gasket fitted, locking bolts added all tightend up no nasty fart noises! :-)
Old 11-19-2014 | 09:21 AM
  #249
weatyGT's Avatar
The latest update is P2647 fault code..... :-( rocker arm oil pressure switch. Plastic housing in cracked so a new one is in need.
Another order for Si at HendyPerformance !
Old 11-19-2014 | 11:21 AM
  #250
Si@Hendy Performance's Avatar
UK Trader
Hi Mark
This one?
37250-PCX-A02 SWITCH ASSY., VALVE TIMING OIL PRESSURE - drop me a message to confirm and I'll get it arranged
Quick Reply: Westy's Progress Thread
