Westy's Progress Thread
Old 10-10-2014 | 12:35 AM
  #191
Daytona-Dave's Avatar
Old 10-10-2014 | 12:38 AM
  #192
weatyGT's Avatar
And to keep the book and lovagroova and my mind all happy.... I'm off to pick up 5w-40 right now! :-)
Old 10-10-2014 | 02:34 AM
  #193
tozerman's Avatar
Good work, worth it for piece of mind. The plunger should not touch the pad until you release the wing nut.
Old 10-10-2014 | 05:59 AM
  #194
weatyGT's Avatar
Yes I think it must have been out a bit further than it should be maybe... or the seal.... not sure! It went in no problem today, like it was just sitting in the hole, so seems should be all ok now.
Thanks so much guys, really appreciate it.
Oil all changed now also. Had a magnetic oil plug to pop in but its the worng size, (Js racing one), my drain bolt takes a 19mm socket the Js was a much snaller thed, as well as taking a smaller sicket more like a 14mm, it went in but didnt have much screwed in and didn't feel confident (if you know what I mean)
Ive continued with magnets on the oil filter with old drain bolt (washer cleaned up) until next oil change.
Old 11-05-2014 | 07:03 AM
  #195
weatyGT's Avatar
So the only update is....
im down to wales not this weekend but next to add all the bits to the car over the weekend.
diff mounts,
spoon rocker cover,
cross brace,
rear brace,
tunnel brace,
HKS manifold,
Removing the air con as I never use it, ever.... so ordering a smaller belt from Si
Clutch kit being ordered to not sure if I should order the stage 2 or stay oem??
Mishimoto triple core X line radiator with the lower temp fan switch and thermostate.
Ill.also attempt to flash pro the car this is my main worry as ive never delt with anyhring of this kind before..... scared!!!!
I think thats all for now :-)
Old 11-05-2014 | 10:01 PM
  #196
Krisbuc's Avatar
Got your parts from zircotec ?
Old 11-06-2014 | 09:34 AM
  #197
weatyGT's Avatar
Not yet but is it is all finiahed and part paid for so its just a matter of paying off and them sending it back :-) will sort this next week. I had email from production as I was just leaving for holiday explaining that it was completed and ready for dispatch.
Old 11-07-2014 | 05:02 AM
  #198
weatyGT's Avatar
Manifold is in the post from Zircotec
Mishimoto triple x line rad is in the post.
Clutch ordered. (Stage 2 perfromance clutch) thanks Si
Low temp thermostate on Si's desk
Low temp fan switch on Si's desk
Aircon Delete belt on Si's desk
There is something else under Si's desk too but hat's for desert :-)
Im now starting to think all the parts may not all fit in the boot!!!
Old 11-07-2014 | 05:11 AM
  #199
BenRNBP's Avatar
In that case I'm going to pop down and visit Si, I may send him to the warehouse while I fleece his desk for goodies
Old 11-07-2014 | 05:37 AM
  #200
Si@Hendy Performance's Avatar
UK Trader
Oi you two! I'm watching!
Did you order the Rad from the USA in the end Mark?
Quick Reply: Westy's Progress Thread
