Weird noises when starting from cold
When I start my S from cold there is a strange rattling/whining noise. It sounds like something spinning with worn out bearings.
It starts about 5 secs after I start the engine, and carries on for about a minute. Then there is a whirring noise, like an electric motor spinning down, and it stops.
It happens every time I start the car from completely cold, but doesn't happen if the car is even a bit warm.
I've opened the bonnet while it's happenning and it seems to be coming from in front of the block to the right (ie passenger side), but I can't pin point exactly what it is.
Asked them to listen to it at Crown Honda last week while it was in for it's service, but they said they couldn't hear it. Asked them to keep it overnight and listen to it in the morning, but when I arrived in the morning to show them, the car was already warm and it didn't do it.
Sorry for the vague descriptions, I'm hoping someone else has had this problem and can tell me what it is.
Cheers
Si
Cheers
Si
Sounds like the aircon unit - it's in the front of the bumper on the passenger side (behind the fake vent)
Mine makes a noise for about a minute on startup and there's a "psssht" noise and it stops... I've seen this mentioned in other threads too...
P
I reckon it could be the airpump which is behind the front bumper, I think it pumps air into the exhaust to help the Cat heat up more quickly. (Something to do with emmissions) Seems to only come on/make the noise when you start from cold.
Originally Posted by GSi,Mar 23 2005, 01:59 AM
with the guy with the stiffy.
Try again with hand on top of the engine, see where the rattle seems to be coming from.
Could be the chain drive wearing out on the front end.
From what I hear, not very nice, but that sounds like I have had it described to me.
If it is from the front of the engine bay then as said before pump / ac etc, nothing to worry about, if as above though
