VSA
Old 07-10-2008, 04:49 AM
Survey S2000's Avatar
VSA will kick in went required unless it has been turned off. Yellow triangle on dash appears as tflpunk says.
When VSA is in operation during and is required to intervene on your right foot action the yellow triangle will blink on and off.
To test it you need to drive with round corners with to much trottle on, best at low speed for safty. It will then cut the power to the wheel as required to aviod excessive backend slip etc. If you want to test it go to an empty car park and turn a sharp corner with much trottle you will notice it!
Old 07-10-2008, 04:50 AM
tflpunk's Avatar
Ooops, sorry, hold down the button to turn it off :-) It's on all the time by default, and the light on the dash will flash at you if it's trying to 'help' you.
EDIT - as stated above
Old 07-10-2008, 04:54 AM
ktrotman's Avatar
thanks guys appreciate your help!!!
i will check it out at lunch!
Kevin
neoarroyo
10-01-2007 05:59 AM
Apee Two
08-01-2007 10:40 PM
Initial D God Hand WannaBEE
02-26-2007 08:20 AM
joefish1298
11-14-2006 12:47 AM
KenS2K
07-11-2001 12:30 PM
Quick Reply: VSA
