ViPEC ECU for DBW cars
http://www.vi-pec.com/
Gaspode and I are still truffling around for a solution to our "DBW so can't go FI" problems.
I have it on reasonable authority that it's possible to convert a DBW throttle back to conventional throttle by using the following
05 ECU + a nice long cut of loom
TB, Throttle cable, Throttle Peddle + brackets
Engine Wiring Loom
Lots of time, money and some pain with blood too.
Then someone on the Mods forum suggested the above, looks nice and has a good rep around the other marques that use them - seems to have lots of features too. They don't appear to do a plug and play version for the AP1 so it will probably require a fair bit of wiring but looks like all the stock sensors will still work with it.
Anyone ever come across this gear?
Engine Wiring Loom
Chris, he is as far I can tell but I just couldn't believe it hadn't been done before. I'll dig into these a little bit more as they look like a nice piece of kit, it's a standalone as well so this becomes a reasonable solution for all UKDM DBW owners.
Scott has PMd Mase to see what he thinks but it's worth having a look at if we don't have to guddle around for a different solution. Also, this might allow me to install RLTC whereas the hondata piggyback would still end up in the same limp home mode problem.
Originally Posted by chrisr111,Mar 18 2009, 11:27 AM
If your looking into standalone options for DBW you could use a MoTec (M4 IIRC but maybe M800) but they aint cheap.
Chris.
Chris.
I'd imagine to convert to conventional throttle from DBW would be
