Valve Clearances
Valve Clearances
Hi All,
My mechanic is giving the S a service tomorrow, car has done 65k & im pretty sure the valve clearances have never been checked! Do you think this is worth doing tomorrow? Or would there be no point? i've done a bit of research and it seems they don't need to be checked / adjusted until around 100k, just thought i would double check.
Ta
Elliot
Ta
Elliot
By the way, it's well worth it and there certainly is a point.
I don't have a degree in Mechanical Engineering and I'm not a mechanic by trade, so Ray and Ron explained it to me in layman's terms last weekend before performing the adjustments.
There's quite a dance going on underneath that rocker cover and the valves need to be in sync in order for the engine to perform efficiently and produce the correct amount of power. R&R said something about their purpose being to aid with the pistons' return strokes / expelling exhaust gases etc.. If they're not correctly adjusted, the worst case appears to be that your engine would overheat, which would cause serious damage.
I'm sure someone with a greater knowledge of the subject will be along...
If your mechanic's happy to have a look, get it sorted!
It can definitely affect the efficiency and therefore the power from the engine, if
the information I have read is anything to go by.
I had mine done a week ago at my full service, and I also had it done the year before - overkill maybe
but I rather get everything done and dusted and keep it running nice.
After my full service everything has been running sweet - not saying it's down to primarily the valve
clearances but it all makes it run better.
It's not even that expensive to get done?
Have a look at this thread:
https://www.s2ki.com/s2000/topic/763...ve-adjustment/
To answer your question, it seems any 'decent' mechanic could do it. It depends on what you call decent!
