Valve Ajustment / Spacing
#21
Originally Posted by GrittyShaker,Aug 15 2008, 10:17 PM
I'm actually due a service right about now. Would love to request your help if I knew there was a hard surface to do it on there.
(The service, I mean. )
#22
Administrator
Originally Posted by Hypersonik,Aug 15 2008, 11:13 PM
Thanks for the praise
I'll bring my feeler gauges and if anyone wants their tappets adjusting and they are at JAE, I don't mind
I need an oil change (all) and diff swap, plus inner CV joint swap too
#23
Originally Posted by Hypersonik,Aug 15 2008, 11:28 PM
Either or Scott, i'm easy
Being serious for a second; can anyone (Ian?) confirm if there will be a hard surface to carry out any work on the cars?
If it's at all possible, I would like to bring along the bits for the service and do it there and then. I'm tempted to do it myself anyway, but having a supervisor help out would be perfick, having not done it before.
#24
Originally Posted by AquilaEagle,Aug 15 2008, 10:31 PM
Just them or tools too?
I weighted up the diff swap for you and TBH, it would be a 3-4 hour job on my back I reckon.
And unfortunately, I won't be able to do the CV swap either as my Ball joint splitter only JUST fitted to the rear control arms! Need a wider one.
Oil changes - no problem though.
Serious, if the grass is hard, i'll get it done.
My mrs went the chippy the other day (4 miles away in Crewe).
I started after she went, and had finished changing the engine oil by the time she came back.
Worse though, I actually went and bought an OEM Filter
But seriously, valve adjustments are a definite!
#25
#26
Originally Posted by GrittyShaker,Aug 15 2008, 10:47 PM
Think you might be clutching at straws there.
Nah, we'll find somewhere i'm sure
#27
Glad to see you're still smiling.
Just looked at the 72k service shedule. It's just an oil change, basically.
Engine and gear oil, plus brake fluid. That's about it. That will cost over
#28
Originally Posted by Stel,Aug 15 2008, 12:19 PM
man if i could i would! ur welcome to come to the garage over the weekend tho if u need a space to do it with some tools. im in north london.
you know we should organize a north london meet
Oh yes a valve clearances fixed my problem with random misfiring I done all the usual checks plugs coil packs fueling turned out to be he clearances
#29
Originally Posted by mugen888,Aug 15 2008, 03:11 PM
stel where is your garage
#30
