Update on my buzzing deceleration problem
I took the car into Slough Honda this morning about the deceleration buzz and was told that this was a common characteristic of all S2000s (despite me giving them a copy of the service bulletin). Hmmm
Sorry, I can't really help you on the buzzing. Yes, the S2000 is noisy and does have various noises because of the close proximity of gearbox, exhaust, etc to the driver. Still, if you feel that the noise is obtrusive or especially loud then your dealer should do something about it. Has the noise changed or got worse, if so I would expect a fault. I didn't know about the clutch problem, until after I had the gearbox changed. They replaced the clutch as well, was far quieter than the original. The noise I had was like someone shaking a tin can full of nails That was over 14,000 miles ago, but now that clutch is sounding noisier. I'm not sure myself if it's a normal noise or not. Maybe we should start a collection of clutch / gearbox sounds?
Your idle problem sounds serious. What has your dealer done to troubleshoot this. It could be a number of things, so I shalln't try to diagnose it remotely. People have reported sensor problems (MAP, SO2, lambda, etc), faulty injectors, loose spark plugs, etc. Mine suffered from an intermittant connection on the engine wiring hardness to the SO2 sensor. This cause an open circuit if I accelarated suddenly in wet conditions. There are detailed troubleshooting tests which your dealer should be following. These detail what remedies to take (which Honda will cover on warranty). This includes replacing the whole engine harness, if all else fails! If they can't / won't attempt to trace the fault, then take it elsewhere! Do they have much experience with the S2000? I think some of the smaller dealers have sold so few that every fault is new to them.
If you have a buzzing, rattling sound like a heat shield rattle that occurs when you decelerate down through 3,500 rpm , then you have a recognised fault, curable under warranty by fitting the -055 clutch. I know, 'cos I've had it done (and a hell of a difference it makes too!)
If this describes your problem, you need to stand up to your dealer. What's his problem anyway? He gets paid by Honda for doing the work!
Yes Pete is quite right, my cars symptoms were as you describe. New 055 clutch plate = cure, and all under warrantee. Insist they correct this, its a recognized fault.
Have not experienced the stall prob, mine occasionally falters if in heavy traffic for some time at idle. The cure seams to be a to lift off them heavy right foot!!!!!
[QUOTE]Originally posted by PWE 896
[B]If you have a buzzing, rattling sound like a heat shield rattle that occurs when you decelerate down through 3,500 rpm , then you have a recognised fault, curable under warranty by fitting the -055 clutch. I know, 'cos I've had it done (and a hell of a difference it makes too!)
dont get discouraged by the buzzing sound., its not a big deal, if its not broken, i would not let HOnda touch my tranny.
it will never be as good as new again.
Originally posted by Ewan
I had the clutch replaced quite early on for this reason, and it did make a big difference - but it's not a permanent cure (the problem has come back to some extent, and I can't really be bothered getting them to do anything about it )
Only when Honda finally REDESIGNED the plate assembly to take account of this (the 055) did the problem become resolved, and that is a very recent event (hence their latest service bulletin on the matter).
Originally posted by bayarea408
dont get discouraged by the buzzing sound., its not a big deal, if its not broken, i would not let HOnda touch my tranny. it will never be as good as new again.
So, what will you do when the clutch wears out?
PsychoBen
02-21-2001 10:15 AM
